跳转到主内容
2024 年 6 月发布的 微软 Surface Pro 11 的维修、拆卸和故障排除信息。
What else do I need to change the case?
I have the Lower Case in my cart, but I am unsure what else i need to purchase from ifixit to put the surface back together?
Also do you really need (Ruck Plates of 9 kg + 9 kg + 14 kg ) like the microsoft document says?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @greel
If you're replacing the LCD panel then to ensure that it bonds correctly with the frame enclosure, you need the ruck weights distributed as shown in the service manual (see p.35→p.36) to make sure that does.
Alternatively you can use a Shot bag filled with steel shot, not sand, to ensure proper weight displacement. Using this is also shown in the manual, on the same pages.
这个答案有帮助吗?
得分 2
2条评论:
Surface Pro 11 OLED Lower Case - Genuine
Im just replacing the case. I was assuming i could reuse the screen. Do i need a new screen too?
完成的
@greel
The part you linked looks like the lower case only i.e. where the motherboard is located and not the lid cover where the display is.
As for whether you need a new screen would depend on if the display works now or not.
完成的
添加一条评论
添加你的答案
Alex Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 172
