How Can it be turned on without the power on button
The power on button is broken. Is there any other way that it can be turned on?
Hi @galvinjaiki
Try the following and check if it works on your model.
You will need a working computer (Windows or Mac) and the phone's power/data cable.
Turn on the computer and then once it has turned on fully etc, connect the phone's power/data cable to it only at this stage.
Then on the phone press and hold the Volume Up and Down buttons (both together) and then plug the power/data cable into the phone.
Hopefully within a few seconds the phone should turn on with a message stating that the firmware upgrade cannot be performed or similar.
When this happens, release both the Volume buttons and then press and hold the Volume Down button.
The phone should restart and start to turn on. When this happens remove the power/data cable from the phone and release the Volume Down button.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 61
总计 356
