跳转到主内容
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
Why my phone is not connect with PC using wire?
I want connect it with PC using cable or wire
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is the phone receiving power but not data, or is it not receiving power at all? I would try verifying that the cable works by checking to see if the cable works with other devices, or if trying to use another cable resolves the issue. If the cable transmits power but not data, it may be a power-only cable, which means the issue can be solved by using a cable that supports data transfer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AAziz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 50
