Washing mashine doesn't go to fast spin cycle - dampers?
My front load lg washing machine LG F2DV5S7S0 - 2 years old does not want to do fast spin cycle (the last cycle) when the clothes do not fill whole inside or the load is unbalanced - typically when i wash fewer bigger clothes like sweatshirts or bed sheets that get stuck more on one side of the drum. It's a new behaviour, never had that problem in past, now it's pretty much every time.
I read it's typically dampers problem, makes sense to me, so I said hey, they are cheap, why not try it, but now when i have them home, I am surprised - the new ones look exactly the same as the ones in the washing machine, but the force needed to move them is like half of the originals...
Now I think I either bought wrong type or I am stupid for thinking new dampers should be harder to move... But I guess the old dampers are simply alright, no need to change them, they are nicely firm, look alright (I can return the new ones, so no problem)
Can someone help me decide what is it? Maybe even help me with some other suggestions what can cause washing machine to not do the last fast spin cycle and instead just spin slowly with pump running indefinitely, but only if the load is not balanced well? balanced load works without problem.
Thanks to all that might try to help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I too bought new dampers thinking that the old ones were worn out and causing the spin cycle not to work. On taking the old ones out they were just as resitant as the new ones, which incidentally did not fit the machine anyway. I still have the problem with the machine not spinning the wash dry. If Itake out half of the load and put it on a rinse and spin cyle even at 1200 it works fine. Still trying to find the cause of the problem The machine finnishes its cycle with no error codes but the wash is still wet.
完成的
@dprice565
What is the model number of the washer?
完成的
添加一条评论
