跳转到主内容
加入维修社区 - 创建账户
4K Ultra HD, 3D, Hi-Res Audio Wi-Fi Built-In Blu-ray Player
Device isn't starting anymore.
Strange thing, when the player is plugged in, if I hit the eject button on the player, the drive will open and close no problem. However, the device doesn't actually power up.
This includes when I push the power button on the device as well as on the remote. The power light indicator doesn't turn on, the software doesn't start up, even though again, the drive opens and closes just fine.
I've tried factory reset, I've tried using a different power cable, no change.
I should say that I've moved recently and it was working before the move but not after.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mistersteel
It could be a loose connection between the boards in the player or something a bit more technical.
Here's the start of the troubleshooting section from the service manual, that may help to find out what's wrong.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mistersteel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 268
