跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
20 个问题 查看全部
WD Blue 2TB disk making sound every couple seconds
Hey. Today my disk drive started doing some weird "beep-beep" sound every 5-ish seconds.
Windows doesn't recognize it. At first, it recognized the disk and said that the directory couldn't be accessed. Then I rebooted and updated windows and the disk didn't show up on the file manager neither on the disk partitions tool.
It has around 2 years of usage, and never gave any issues.
I have a lot of important data in it.
Is it cooked? or fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It's definitely dead. In regards to the data, taking the drive to a data recovery specialist in your area is the only good option.
这个答案有帮助吗?
得分 0
2条评论:
I think so. I went to a tech support here in my town, and he said that was the only good option. It's pretty expensive tho. How much do you think they charge? He said about 400-600 bucks.
完成的
@joaquin46768 The cost of data recovery can vary widely depending on where you take it and what needs to be done to recover data. But those price ranges seem in scope. Sometimes it’s as simple as firmware (I doubt that’s the case for you). But it can require transplanting parts from donor drives, really delicate repair or more advanced recovery software.
More skilled repairs usually incur higher cost.
完成的
添加一条评论
添加你的答案
Joaquín 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 22
