Glass on Front Shattered
Ipad was dropped and landed flat, glass down. it shattered, but is still in place and the Ipad works, I want to make sure I am ordering the correct parts to repplace the glass.
If it is a 1st generation iPad you need to purchase a 3G model screen as the 3G and Wifi-Only screens are different. My recommendation is to purchase the frame and screen already assembled as it is MUCH easier to install that way as all you are doing is removing the frame and then installing the new frame instead of actually having to pull out the glass.
So be sure that when you are purchasing the screen that it is for a 3G model iPad.
If it is 2nd generation, the screens are all the same. Doesn't matter which one you buy.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 405
1条评论
What is the Model number on the back of the iPad? It should be an AxXxX number.
由 Mike 完成的
