跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
lid sensor location MacBook Pro M1 base model (2020)
Where is the lid angle sensor located on the MacBook Pro M1 (2020)? After cleaning the speaker, the lid angle sensor stopped working. When I close the lid, the screen stays on and the MacBook does not go to sleep. Before cleaning the speaker, it was working perfectly. Can you help me locate the lid angle sensor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Which model? 13” or 15” they are different
完成的
@danj 13" sir
完成的
添加一条评论
1个答案
The Hall sensor is mounted on the backside of the logic board which I’ve marked here. This is not an angle sensor design which is used on the 15” models.
Using a rare earth magnet passing it over the top surface of the palm rest you should be able to fire it off. If not could you have damaged it?
这个答案有帮助吗?
得分 0
4条评论:
If that’s indeed its proper place, it should be out of reach. Could it be possible that it got dirty while cleaning the speaker?
完成的
@maulanarafi - Dirt won’t effect it, but some liquids could effect things here, basically creating a short. How did you clean the speakers? Did you use a water based cleaner or one with ammonia.
完成的
@danj No, I didn’t use water. But could it be fragile? I only used a used toothbrush to clean the dust from the speaker holes.
完成的
@maulanarafi - Well… I wouldn’t call it fragile, but like most SMD devices the solder joints hold the part to the PCB so it’s possible to knock it off. But there are other components also involved in the sensor for it to work. So you will need to compare the logic board with the one I posted to see around the area if there is a component missing. You’ll also need to look on the other side as well as not everything is on one side.
完成的
添加一条评论
添加你的答案
Maulana Rafi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 72
总计 1,309
