跳转到主内容
加入维修社区 - 创建账户
Ninth generation of iPad, released September 24, 2021, available in 64 or 256 GB models. Model Number A2602.
iPad won't charge or turn on after battery change
I replaced the battery in an iPad 9 and now it will not take a charge. Everything was functioning fine after with the new battery. Then a short time later it will no longer charge. When I connect a USB power meter it shows 0.01 amps. Nothing changes with a different charger and cable. Is this a board level problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
One of the most common issues with iPad repair is that the battery connectors on these are really easy to damage because all the pins are on the underside of the connector. And so they are often bent went trying to isolate them from making contact with the board.
The thinner pins on the far ends of the connector are used for battery data—that means your board may not be getting some sort of data it needs about the battery. So it may not be charging because it doesn't even think a battery is connected. Or that it thinks the battery is full, or it's just confused. Could be any of the above, but it's the first thing I would check in this case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Julian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 119
