跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
iPhone turns off when removing case
Iphone 11 PRO MAX, turns off while removing covering case. Only on the top right corner of the phone, when looking from the screen facing me.
Is this a logic board issue or could it be a loose connector or something else?
For context, the battery was recently changed but not by me.
Whats my best course of action at this point?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like something may be shorting to ground, or some other electrical line when under pressure (assuming there is some flexing and struggling when removing the case). Most likely something is getting squished into something else it isn't supposed to be. Could be any number of things, but I will specifically call out that the main power rail for this phone does go to the display, so this could be as simple as the cable for the display is getting pinched, or was damaged.
If the battery was changed recently I would take it back to the person who did the repair and let them know since it sounds like this was something that started as a result of the repair.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Imre Kaljuvee 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 5
总计 77
