跳转到主内容
The Canon EOS Rebel T7, also known as the EOS 2000D, is an 24,1MP DSLR camera released in 2015.
9 个问题 查看全部
My Screen is cracked!
Is it possible to replace a screen window? It’s cracked, it’s not affecting the LCD itself & it works, but it’s just the fact that it’s cracked & bugging me. Is there a way to fix the screen, or anywhere I can take it? Many thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
So just to be clear, it's only the protective screen cover that's cracked and not the screen itself? If so, it should be possible to replace it. That protective screen is held onto the back cover with double sided tape. Unfortunately I don't have the parts catalog for this specific camera, but the part name is "TFT Window". If the remaining tape isn't sticky enough after removing the window, you may also need to replace the tape also. Ideally you'd use the correct tape made for attaching the window to the camera, but you might also be able to use some other type of double sided tape if absolutely necessary.
I haven't done this repair personally, so I'm not certain on the proper way to remove the window. It might be possible to pry off the window without disassembling the camera at all, using something like a plastic pick (don't use anything metal). If it's not possible to just pry off the window without any disassembly, then this guide will show you how to disassemble what you need to in order to get at the window. It's for a different model, but the steps should mostly all match up pretty closely.
If you don't want to do the repair yourself, I'd imagine any camera repair shops that services this model of camera should be willing to do the repair for you as long as they are able to get ahold of a replacement window. If a replacement window can't be found, then the next solution would be to just replace the whole back cover, which would work, but also probably cost a bit more money.
Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive.图片
产品
iFixit Opening Picks (Set of 6)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Callum Reynolds 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 30
