跳转到主内容
A 10 speed blender released by the Oster company. Model number: 006706-BG3-000.
What Tool is needed to open the base from the bottom?
I have replacement parts to replace the items that have worn away with use, but I don't have the right screwdriver to open up the bottom. What do I need? I have the Oster 14 Speed All Metal Drive. Probably 20 years old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @andrea71463
Post a close up image of the screw head(s) on the bottom of the blender as it will help to identify the screw and the type of driver required.
Here's how on ifixit 在已经存在的问题里加入图片
完成的
I'm sorry I can't get a good picture. The screws are recessed about 3" and appear to have a very flat phillips head design. In the YouTube videos I've seen, the repair person uses a drill to remove the screws.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @andrea71463
It is a bit hard to make out, but if there's a post in the centre of the screwhead then to me it looks like a Torx security (aka tamperproof) screwdriver (or driver bit) may be what is required.
If not then an ordinary Torx head screwdriver (or driver bit) should work.
A Torx head screw has 6 points in the screwhead, whereas a Philips head has only 4 points.
Regardless of which it is, it is also difficult to determine the correct size screwdriver or bit to use. The only thing that is definite is that a long shank screwdriver or driver bit is required i.e. 4" or 100mm.
Long shank torx head security drivers are available online and in hardware stores. The link is an example only to show the hollow in the driver head to accommodate the centre post in the screwhead (if there is one) and the number of points i.e. 6. For the length of the bit you may need 100mm (4") and not 75mm (3") just to be sure.
Here's a chart that shows how to determine what size Torx driver is required as it shows the relationship between the point to point distance (inches and metric) and the Torx T size number.
Here's the parts list for your model - Oster 6694 but it is of no help, in that whilst it shows the part numbers for a lot of the parts, it doesn't for the two screws that hold the base.
这个答案有帮助吗?
得分 2
1条评论:
Thank You! I'll bring the base to the hardware store.
完成的
添加一条评论
添加你的答案
Andrea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 173
