跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Apple mac won't power on.
Using the Mac as I normally do then rebooted it into bootcamp.
  • Display just showed faint glow and sat there.
  • Hard reset it. Exactly the same.
  • Reset nvram and pram. Still the same.
  • Safe mode boot. The same
  • Network boot. Recovery. Diagnistic boots all the same.
Internal board LED diagnostics
Computer off
  • 1 on
  • 2 off
  • 3 off
  • 4 off
Power on
  • 1 on
  • Followed by 2 on
  • Followed by 3 on
  • Followed by 4 on
  • All 4 on
  • 3-4 seconds later 4 goes off.
Unplugged, cleaned and reseated display. Still the same.
  • Checked main board with thermal camera. All OK. No hotspots.
  • Fan on idle.
Any answers or what to check.
Need to use my computer urgently.
Cheers
Mac
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
the only things that could work that you haven't already done is checking the connectors and replacing parts though there is a list of guides on how to replace the various different parts iMac Intel 27" Retina 5K Display (Late 2014 & 2015)
这个答案有帮助吗?
得分 0
添加一条评论
What is your drive setup? Fusion, SATA HDD or blade SSD or did you change the drive out.
The onboard diagnostics are reacting normally so the logic board is doing what’s expected. That aims us to the drives and the low level and OS held on them.
Do you have a macOS bootable external drive to startup the system? You’ll need that and ideally the same version of OS your system is currently running.
这个答案有帮助吗?
得分 0
9条评论:
Fusion drive failed years ago. Replaced with ssd.
Current ssd changed last year.
Old one put in. Exactly the same. 4 lights in order. 4th goes out.
So not ssd failure. (It was same os on the old disk)
I'll have a look later. Off to get the mini m4 pro.
完成的
@theridgeback - To be clear you swapped out the blade SSD or did you swapout the SATA HDD to a SATA SSD?
As this was a Fusion Drive’d system you really need to pull the blade SSD as you really don’t want it still in there if it’s dead or not used.
完成的
It was the blade that failed. So I removed both drives (bit of a ball ache) and put in a standard ssd. That was probably 2018. I upgraded the old ssd last year to 2TB as the wife wanted windows on it and couldn't be bothered to dejunk it for space. I still used the old drive to ocasionaly externally boot from it as well.
完成的
@theridgeback - using that external are you able to boot up? You’ll need to engage the Startup boot disk manager Option (⌥) as described here Mac startup key combinations
完成的
Nope. Tried all of that. No safe mode
No diagnostics. No network boot. No boot select using option key. Nada.
I've tried everything that a normal person would try.
The only thing I have not tried is verbose. But as the screen isn't working it's pretty pointless.
One other thing to mention.
There is no chime on any of the boot attempts.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
The Ridgeback 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 14
总计 133
