跳转到主内容
加入维修社区 - 创建账户
I can't find a battery replacement part for HP Omen 17-an032ng
  1. Is there any aftermarket options ?
  2. It isn't available in my country (Turkey)
  3. Can I just take off the battery and directly plug it into the wall ?
  4. Is there anything I should know about laptop battery replacements since I'm new with laptops
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @sarravo
Here's the maintenance and service guide, taken from this support webpage for the laptop.
Go to p.38 (p.50 of 99 pdf) to view the procedure to remove replace the battery.
Here's a supplier that may help, depending if the cost is acceptable to you of course.
Alternatively search online for 922976-855 battery and check if you find other suppliers that are more suitable.
It is not advisable to run the laptop directly on the charger without a battery installed.
When working inside a laptop, make sure that the laptop is turned off and the power is disconnected. Then disconnect the battery from the motherboard i.e. as soon as it is accessible before doing anything else. Doing this will minimize any potential electrical problems from occurring if you happen to touch anything you shouldn't. There's always power on the motherboard somewhere, even when the laptop is turned off. The power button is not a power isolating button.
Keep a jar/container nearby by place in any screws that need to be removed. Use a different jar for each set of screws removed e.g. back cover screws, battery screws so as not to mix them up or lose them.
Also wear a wrist strap connected to an earth point so as to not cause any ESD damage to any sensitive components that you may touch.
Lastly take your time. I'm sure that you'll be fine
这个答案有帮助吗?
得分 2
2条评论:
thank you so much this is pretty much it, but I got stuck at a point. Since I'm helping a friend I don't know which battery to buy. The laptop has 2 variants the 1070 uses 16 pin and 1050 uses 12 pin one. He doesn't remember which gpu he had and searching the serial number gave us nothing too. I don't have physical access atm. All I have is model no/proID and serial number. Should I just get the 922976-855 battery (16 pin) and hope it's the correct one.
完成的
@sarravo
Bit confused here when you say that the 922976-855 battery is a 16 pin. Is this a typo by you?
Looking at an image of the 922976-855 online it has 12 pins and NOT 16 pins
According to the specifications, the laptop has a NVIDIA® GeForce® GTX 1050 Ti GPU
On p.38 of the maintenance and service guide linked above it says to use battery part number 922976-855 with the above GPU.
The 1070 and 1060 uses battery part number 922977-855 ( an image online shows 16 pins)
完成的
添加一条评论
添加你的答案
Joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 150
