跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
How to change the keycaps
I need to replace the keycaps on a old touch bar MacBook pro is there anything that I should know as I'm used to PC laptops and have never worked on a MacBook is there anything that I should know?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
These key caps are extremely easy to break. So going in prepared is key. :)
If you haven't taken a look at the internals of the key switch here's a picture that will probably help more than anything.
This image is a bit newer model, but the mechanism is largely the same. The key to damage free removal is to use something slim (like iFixit's Jimmy or an iSesamo) to get under the top edge of the key cap. That's the side with the clips, and the bottom edge has a little hinge in each corner that can take the posts on the key switch out too if you're not gentle.
There's also a Guide if you want a more step by step.
Springy steel blade features a smart tip design and a handle with a great no-slip grip. Effortlessly pops open iPod, iPad, iPhone and many other tablets, smartphones, and devices.图片
产品
iSesamo Opening Tool
$9.99
Handy tool for opening electronics.图片
产品
Jimmy
$7.95
这个答案有帮助吗?
得分 2
添加一条评论
Here is a good video that shows you how to replace the keys :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
frey_code 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 26
总计 185
