跳转到主内容
A2115 / 2020 / Processors from 3.1 GHz 6-core i5, up to 3.8 GHz 8-core i7. Released August 4, 2020.
upgrade to any release except mojave impossible after disc change
Hi, how can I upgrade to Sequoia or previous releases an A2115 / 2020 iMac?
I have made this upgrade several times on iMacs easily, but this time I'm getting crazy about this operation.
The new drive is an 870 QVO by Samsung and I have previously split the Fusion drive. (prev. configuration 1TB seagate Hd + 28Gb apple ssd)
I've tried with any OS installers, even with Open Core, but I get the same result: Impossible to verfy the installer, or sometimes installer corrupted...
What can I do? Thanks...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Apple has really cracked down on their os so it could be related to that
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly the hidden Blade SSD is being seen by the OS installer trying to setup a Fusion Drive config. The best way is just to pull it out, I know a big pain! The other option is to create a bootable OS installer which you use to wipe the Blade SSD so it’s not recognized by the OS installer.
So… setup a bootable USB thumb drive by first formatting it to GUID and a Journaled file system (HFS+) copy the OS installer to it and then modify it following this guide Create a bootable installer for macOS
After booting up under it open Disk Utility and delete the partition on the Blade drive and I would format the drive MS DOS and now run the OS installer setting up the new SATA SSD drive
这个答案有帮助吗?
得分 2
3条评论:
Pulling down the hidden blade... so much work! :-) I'll try the soft way first thanks...
完成的
Hi, Dan... The main problem was this terrible fusion drive, I've split it and put to sleep the "hidden" SSD... but there was the second problem causing the "general error message" with any kind of installer...
One o the two ddr4 ram module was misfunctioning, I've run several times the Apple hardware check but with no errors, so I do it in the old way: I have removed the first module and the Imac did not start, instead with the second one everything was running fine.
The problem is now completely solved and the customer is happy...
Thanks a lot...
完成的
@ugopagotto - Happy you found that second problem!
完成的
添加一条评论
添加你的答案
Ugo Pagotto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 103
