跳转到主内容
Why is my pc taking too long to start up?
It takes almost 6-7 mins before it starts up!
I've tried several ways to solve the problem: toggling off the startup apps, optimizing the machine for the best performance, uninstalling several apps that I found out I didn't need (and probably were the cause of the problem), running some command prompt programs for fixing maybe any corrupted files and restoring the health of the machine, etc...
All of these, and more, haven't worked!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi @kipngenoaron
Have you tried starting the laptop in safe mode to see if it starts faster?
Also try repairing the startup and check if that resolves the problem.
Use the link above and then scroll down to the section headed Enter Safe Mode from outside Windows and when you get to the Options menu, select Startup Repair and follow the prompts.
这个答案有帮助吗?
得分 1
添加一条评论
Well try the following:
  • Disable unnecessary startup programs.
  • Clear up space on your boot drive.
  • Run a malware scan.
  • Access BIOS to tweak those settings.
  • Restore or reinstall Windows.
  • Upgrade your computer's hard drive and/or memory.
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like there’s a deeper issue. Check your hard drive’s health, update drivers, and scan for malware. If you’re still on an HDD, switching to an SSD can hugely improve boot times. Event Viewer can help identify the exact delay cause.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kipngeno Aron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 132
