跳转到主内容
发布于2021年的7寸电子墨水屏阅读器,附实体按键,有黑/白两色。
Phantom, erratic page turning and high lighting
My kobo seems to be possessed. I attempted a manual factory reset. It was promising at first, I was able to get through all the set up prompts and sign in. As soon as I got to my home page, the poltergeist started opening all the books and highlighting again. The screen is also had a shadow on the lower right corner.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
We see this phenomenon on phones occasionally. It's popularly referred to as "ghost touch" and is a result of damage to the digitizer that allows electrical noise on the signal lines that gets picked up by the processor and interpreted as touch inputs.
Unfortunately this is a hardware problem and the only solution is to replace the digitizer. On phones that means a complete screen replacement, but that may or may not be the case on your eReader. Some tablets do come with separate components for the display and the touch screen, while on others they're fused as a single unit.
A big problem here is that according to Kobo, the Libra 2 isn't designed as a repairable device like the Libra Color, although it's not clear to me exactly what all the differences between the two are. It appears from the Libra Color guide that the display and digitizer come as a single unit, so my guess would be that yours probably is too, but I wasn't able to locate a replacement guide so I can't confirm that. Likewise I had no luck finding replacement parts for it either; I'm guessing the e-ink display hasn't made it into the mainstream aftermarket industry.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Breanne Price 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 47
总计 635
