跳转到主内容
SE 2022 Charging Port Available?
Is a replacement charging port available for the Iphone SE 2022?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I'm not clear as to whether you were set on getting a genuine Apple replacement part or not, but if not the ports seem to be readily available on several sites such as Amazon, eBay and AliExpress.
Amazon.com: Risidamoy Dock Connector Charging Port Replacement for iPhone SE 3rd Generation 2022 Repair Fix USB Charge Headphone Jack Microphone Antenna Flex Cable Assembly for iPhone SE 2022 : Cell Phones & Accessories
AiinAnt USB Charging Port Charger Dock Connector Charging Flex Cable For iPhone 6 6s Plus 5S SE 2020 2022 Phone Repair Parts - AliExpress
iPhone SE 2022 Charging Port Flex Red - eBay
Note that last one is in red; it's strictly cosmetic though so it would work fine; of course if you look a bit harder than I did you'll undoubtedly find the right color for your phone.
Finally if for some reason you are dead set on a genuine Apple part, I did run across a used one on eBay.
Charging Port For iPhone SE 3 2022 - 3rd Gen Dock Connector Flex Cable in Black - eBay
All in all, the charging port for your phone doesn't appear to be any harder to get than that of any other given phone.
I realize you're probably aware of this already, but here's the guide for that specific repair on your phone.
iPhone SE 2022 Lightning Connector Assembly Replacement - iFixit Repair Guide
这个答案有帮助吗?
得分 2
1条评论:
I kept finding the older part, thanks Jerry!
完成的
添加一条评论
Here’s a link to the Apple repair guide Apple's iPhone SE 2022 Repair Guide
I’m surprised Apple doesn’t offer the part as it’s one that often wears out or gets damaged by sand. A quick search I’m unable to find the part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 34
总计 300
