跳转到主内容
加入维修社区 - 创建账户
Meta Quest 2 (Oculus Quest 2) 是 2019 年 5 月 21 日发布的 Oculus Quest 的继任者。Quest 2 是一款经过改进的型号,具有更好的处理器和重新设计的触摸控制器。
Turning on automaticity when charging
Hey there, so my quest 2 is having a issue where whenever it’s plugged in to charge it will power back on, I have tried everything to troubleshoot shoot and think it’s a technical issue was wondering if you ever seen this before or know how to fix it
I have swapped the proximity sensor with a good one to see if that was it bc I thought it could be but nope still same issue
Only other thing I could possibly think is the usb charger port/cable but I’m not a pro when it comes to small device repairs so don’t wanna risk it without more details and testing
Idk how this question works but if needed my email is tntn3rd@gmail.com
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Yes it is fully powered off and no it is not the charger cable
I have two quests and only one has this issue
(It isn’t a user issue)
完成的
Does it actually fully turn on?
完成的
添加一条评论
2个答案
已选择的解决方案
After trouble shooting for a while and trying everything from the most basic fixes to complicated ones I was able to fix it
I had to replace the charger/port flex cable to fix the issue and to clarify I don’t mean the charger cable I mean the flex cable inside of the headset it self so I took it apart and replaced it with a new one
Sure this wasn’t a huge issue bc the headset was fully functional but it was an issue nonetheless and I have OCD so I had to fix it for the life of me lol
这个答案有帮助吗?
得分 0
添加一条评论
Is the oculus fully powered off, or is it in sleep mode?
这个答案有帮助吗?
得分 0
1条评论:
Yes it is fully powered off, the issue had to do with the power cable
完成的
添加一条评论
添加你的答案
TnTN3Rd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 38
总计 547
