跳转到主内容
HP Part#: CN731A#B1H: Printer, scanner, copier, web browser with wireless internet capability
16 个问题 查看全部
Can you help me install the driver for my printer?
after the power went out the printer was deleated from my system I tried to reinstall from hp site and keep getting the message The print Spooler Service is not running. Even tried a other printer with disk got same message would not let me install it either.can you help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Follow the steps below to check the print spooler.
1. Type service.msc or just services in the run (XP) or Search programs and Files (Win 7 & Vista)
2. Click on the Service (Local)
3. Scroll down the list till you get to Print Spooler, and then click on it once to highlight it.
4. In the upper left corner you can stop and then start the spooler to make sure that it is running.
5. If it is already running, try stopping and then starting it up again.
Let me know if that doesn't solve your issue and will advise otherwise :)
这个答案有帮助吗?
得分 1
添加一条评论
Seems like some of your registry values are disturbed by this fluctuation. You can first try to fix your registry by downloading and installing the ccleaner. Once installed run a thorough scan and then apply fixes. After your apply fixes then try to re-install your printer again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Janette Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 861
