跳转到主内容
he Xiaomi Redmi 8 is a low-budget smartphone by Xiaomi released October 2019. It has a 6.22" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Snapdragon 439.
Why does my signal in the suburbs have a bad signal?
Why does my signal in the suburbs have a bad signal? even though my friend's signal is good, the SIM is the same and the phone is also the same. I have used it for 4 years, the 4th year with signal problems. if it's a network Why does my signal in the suburbs have a bad signal? even though my friend's signal is good, the SIM is the same and the phone is also the same. I have used it for 4 years, the 4th year with signal problems. If the network is good. Very bad signal
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Probably different plans and a bandwidth problem. Limited service speed in your area and your plan may not pull in enough bandwidth for better speeds. Or you have a defective sim or component.
这个答案有帮助吗?
得分 0
1条评论:
You are wrong !! I tried even changing my Sims.....at different places still have calling and internet issue.
完成的
添加一条评论
添加你的答案
Ss Framm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 78
