跳转到主内容
加入维修社区 - 创建账户
The Sony Smart Watch SW2 is a smartwatch created by Sony. The model number for the device is SW2 1271-4651.1.
The smart watch doesn't turn on
I was using it for long but now the watch doesn't turn on after charge. Plz advise
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your Watch isn't turning on after charging, here are some steps you can try to troubleshoot the issue:
Check the Charger and Cable: Ensure that the charger and cable are functioning correctly. Try using a different USB cable and charger if possible.
Charge Longer: Leave it plugged in for at least 30 minutes to an hour. Sometimes the battery might be too depleted to power on immediately.
Force Restart: If the watch is unresponsive, try a force restart: Hold the power button for about 10-15 seconds until the watch vibrates.
Software Issues: If it powers on but doesn’t function correctly, it might need a software reset or update. You can do this via the companion app on your smartphone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nayak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 31
总计 429
