跳转到主内容
加入维修社区 - 创建账户
苹果 14 Plus 采用 6.7 英寸 OLED(与 Pro Max 一样),和iPhone 14 一样,iPhone 14 plus 具有双摄像头和 5 核 GPU 的仿生 A15 芯片。
iPhone 14 plus reboot randomly
Hello everyone, I'm posting a message here because my phone (iphone 14 plus) crashes and restarts by itself, I have the crash report, I need you to try to solve the problem, it's been like this for a month now, it's driving me crazy, I've switched back to the iphone 8 plus just long enough to understand, so if anyone has a solution I'll take it! https://pastecode.io/s/qoixm17c
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Your iPhone may have a damaged battery, or it has a damaged. internal part. Maybe iOS itself is corrupted and needs to be restored, if that's the case then you will need to restore the phone using iTunes.
完成的
添加一条评论
1个答案
I had similar issue, was under Apple Care, they rebuilt the entire phone. At a service center, it was great till Apple care ended, a few months.
Back to the same issue, random reboots and now randomly heats up.
Tried:
Removed protective case.
Turned off all background apps
Turned off app updates/refresh.
Deleted apps.
Do not carry in my pocket.
Bought a new Apple Charger/cord.
Do not use the induction charger any longer.
All this helped but still have the issue it is all random.
Do not expect a lot of help from Apple.
Irony, I traded up from I phone 11 with no issues, to the 14 plus, that was great for a few months.
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matheo Maufroy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 44
总计 327
