跳转到主内容
Computer still says "service "recommended" after replacing battery.
After replacing my battery and calibrating it per the enclosed instructions my computer still says service recommended.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
14条评论
Where did you buy the battery?
完成的
I bought the battery from IFIXIT as I have before with no problems.
完成的
@jeffreydm - Install CoconutBattery let’s see what it tells us. Post a snapshot of the Apps main window here so we can see.
完成的
Thanks for the recommendation but I won't download anything that doesn't come through the App Store.
完成的
@jeffreydm - Then you’ll need to visit an Apple Store. I can tell you I’ve used this app for many years and I run a good set of antivirus and malware on my systems and I’ve never encountered an issue with it. CoconutBattery is a safe app.
I commend you on being safe, but you can also goto far just limiting your self to the Apple Store.
完成的
显示更多的9条评论
添加一条评论
1个答案
最有帮助的答案
Sometimes you can resolve this issue by doing an SMC reset and a PRAM reset! Also you can try booting into Safe Mode or putting the new battery through a full charge cycle (charge to 100% and then discharge normally). I've had to do this after installing third party batteries before. If the message doesn't go away after taking these steps, then I would recommend trying to return the battery for a refund. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jeffreydm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 71
