iPod won't turn on when plugged in.
Hello!
My iPod touch 2nd gen was working fine, but when I unplugged it it shut straight off.
Now when it's plugged in, it won't turn on.
I have already tried holding home and power button. That didn't do anything.
Any Suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
I also only have 1 dock cable, how can I check if it’s good?
完成的
Try shining a light on the screen just to check for backlight ic failure common issue back in the day.
完成的
No. No signs of life at all ☹️
完成的
How was battery life on last use? Had you noticed any decline in it at all? anything at all unusual before it died or odd behaviour? Was it dropped or damaged even mildly In any way? Any work done to it? How long since last use how long have you owned it?
A lot of questions I know but the more info the better. It’s basically a screen issue, Battery, charging dock connector, Cable or the motherboard. Most likely a motherboard issue tbh.
完成的
I think the battery was almost completely dead. When I unplugged it turned off as soon as I took it out. I tested snd the 30 pin is ok.
完成的
添加一条评论
