跳转到主内容
Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
Freezer not freezing sufficiently
Amana bottom freezer fridge.(XRBS017BW)
Freezer cannot maintain sufficient minus degrees....thus fridge is also too warm.
Compressor running frequently
Door seals OK
Condenser coils clean
Refrigerant OK
Thermostat in freezer changed
What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I can add that the fridge has been unpowered for 18 hrs to melt any ice.
A quick reset has been tried.
Compressor starts when temperature dial is tapped a little hard..
完成的
添加一条评论
1个答案
What is the frig temp? How old is the unit?
A few possibilities:
Defrost cycle stuck leaving the heaters on
Something internally blocking the system copper lines
A problem with the filter/dryer (part of the system that may be causing above)
这个答案有帮助吗?
得分 0
1条评论:
Freezer temp: -6 - -8'C
Fridge : + 9'C
Refrigerant is presently double of recommended amount to try help on the temps.
Please note that compressor oftently starts when temp dial in freezer is tapped
完成的
添加一条评论
添加你的答案
Mikael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 77
