跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 16" 2021 的维修指南、手册和故障排除帮助。获取自己维修 MacBook Pro 16" 2021 所需的一切。
Removed command key, now it's flat, no spring, doesn't work
I removed the command key on my 2021 MBP because it was a little sticky and when I popped it back on, it goes all the way down - It's lower than the other keys. It doesn't spring up, and doesn't click anymore.
Is there a simple fix for this that I can do myself? I tried removing the key again and replacing it, but maybe I broke the bouncy mechanism when I pulled it off.
Thanks for your help!
2021 MBP with backlit magic keyboard
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did you get the scissor mech into the slots in both the metal frame and in the key cap? There is a small rubber bumper which sits in the middle of the key assembly did you forget it?
完成的
bumper is there, and somehow it worked when I took it off again and slid it back on. Maybe the scissor mech wasn't in the slots at first. Still not clear on what that part is, but all good for now. thanks.
完成的
添加一条评论
1个答案
已选择的解决方案
It's pretty easy to damage the keycap itself or the mechanism beneath it when removing these keycaps. My guess is that there is some damage that happened somewhere. Without high quality images of the parts involved it's difficult to make a recommendation since we have no way of knowing which part is damaged. One thing you can easily double-check though is that the little silicone nipple-like bump that normally sits directly below the keycap is present. Sometimes those come loose and when they do they can slide out of position or fall out which will cause the keycap to not sit correctly. If it turns out though that another component is damaged or some of the clips have become damaged, then you'll need to replace that component. Good luck!
这个答案有帮助吗?
得分 1
2条评论:
The bump is present. I guess it wasn't seated right. I took it back off and replaced it and now it's fine. thanks.
完成的
Nice! Glad it worked out.
完成的
添加一条评论
添加你的答案
Tom Maroney 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 87
总计 494
