跳转到主内容
骑记电助力折叠自行车是小米第一次进入电动自行车市场的首款商品。 拥有250W高速电机,配备松下18650锂电池组。 禧玛诺内3速花鼓 以及力矩传感器,一次充电可以助力骑行45km。 它同时配备有行车电脑可以将您的手机通过特别的应用连接。 同时自行车也是可以折叠的。
power disconnecting when hitting a bump
my screen/power goes completely off when riding and hitting a bump. I need to push back a little bit the battery to the front to be able to power on again.
it started some time ago but latelly is so often that I need to do it every time I face any crack or object on the road. Usually a little push on the back side of the battery (red light) is enough to power on again, but after just a minute if the road is bumpy it goes off again.
I suspect is related to connections between controller and battery, and I will tear it down if I need, but I wanted to know if someone is having the same problem.
this is NOT the same as losing assistance, that's another unrelated problem. my screen goes off completely, not just the assistance.
I didn't find anyone complaining about this so please, contact me if you're facing the same issue.
muzzol@gmail.com
EDIT: I found a video describing a very similar situation
https://www.youtube.com/watch?v=IRyQtrLo...
unfortunately the guy just returned the bike, so no real solution for us.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I'm answering my own question as I was able to dismantle the controller and fix the issue.
the problem is that there's a gap of about 3 or 4 milimeters between the socket on the controller and the female part on the battery.
[image|3422950]
I managed to scrap a little bit of the plastic from the limit of the battery line
[image|3423003]
I also put a little piece of metal on the affected socket to amplify the contact with the pin
[image|3423013]
and bent a little bit the affected pin to increase the pressure on the metal part of the socket.
完成的
添加一条评论
1个答案
已选择的解决方案
这个答案有帮助吗?
得分 0
1条评论:
please, feel free to contact me if you need further explanation or if you find another solution to this problem.
完成的
添加一条评论
添加你的答案
muzzol mussol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 138
