2 large and 2 short beep with blank screen
Whenever I start my laptop it beep with 2 large beep followed by 2 short beep and with black screen please help somebody
Hi,
Apparently this combination of tones is related to the BIOS system, which means that it has become corrupted and isn’t able to tell the rest of the system what is installed and what information buses they use, so the machine cannot start.
If you still have access to the BIOS setup menu through the Function button for your device, then you can try a BIOS restore which may resolve the issue.
If you no longer have access to BIOS then you will need to take it to a repair shop that will remove the BIOS, erase it and re-flash it to restore the operation of BIOS and the computer.
Hope this helps
Here’s an image of easy steps to try.
这个答案有帮助吗?
Here’s a video of the same problem.
https://m.youtube.com/watch?v=9VCXYcyiCq...
You’ll see what it takes to fix if access to bios is lost.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 92
