跳转到主内容
2020年末13寸 MacBook Air 的维修指南、手册和故障排除帮助。获取自己维修 2020年末13寸 MacBook Air 所需的一切。
Why won't my MacBook turn on?
Hey guys, so this all started a few days after I updated my macbook to Sonoma 14.5 I believe. Don't know if it was the reason, just speculation. Ok, I was using my laptop and all of a sudden, it shut down. I tried to power it on but nothing. Then I went to charge it and it turned on. However, something killed my battery immediately because it was about 50% charged before it shut down the first time. I used my laptop and everything was fine. The next day, I went to pick up my laptop and it didn't turn on, plus the trackpad didn't click like normal. It's like it was stuck. I plugged the charger in and out multiple times and finally the laptop turned on but the battery was fully drained. Afterwards, I fully charged the laptop and used it. The trackpad went back to clicking nice and easy. The next day, samething happed. No response from the laptop whatsoever and I did every possible trick to smc, nvrm, holding the power button, pressing all kinds of keys and charging it,etc. Still nothing so I ordered a new battery and usb c port because I thought the battery was the issue. Changed the battery and usb c port since the old usb c port was a little beat up. After I changed it, I plugged in my laptop and it turned on again. Then I fully charged it. Thought the problem was solved but the next day, same thing happened. It didn't turn on or give me a hint of life. Did all the tricks, detached and reattached the battery, nothing. Detached the battery then charged the laptop, still nothing. I even tried to revive my laptop with another macbook by downloading the apple configurator and doing dfu but still nothing. Does anybody have answers?Don't know what to do at this point and don't want to spend 1,000 dollars on another macbook air m1. Don't have a warranty.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here are few things that you can do to turn on your MacBook:
  • Try resetting the SMC or T2 chip on your MacBook.
  • Try booting into Recovery Mode.
  • Reinstall the macOS operating system.
  • Check if the power cable is not damaged.
这个答案有帮助吗?
得分 0
1条评论:
Did all of those steps already as mentioned in my post.
完成的
添加一条评论
添加你的答案
Luke 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 10
总计 122
