跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
Would a 2019 logic board work in this model?
I’m looking to upgrade my 2017 iMac and I understand that the stock board will only support up to a i7-7700k. The 2019 board supposedly works with up to a i9-9900. When looking at part compatibility the screens seem to be cross compatible which was my biggest worry.
Looking around the internet the only example I can find of the board swap working was on this forum. A user on here swapped his 2017 27” board for a 2019 27” board and claimed it worked but he didn’t go into any more detail. I am not worried about the cost of the swap since I got the computer for $25, I just want to mess around with it and upgrade it as best as I possibly can!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The 21.5” systems use a different logic board than the 27” models. Apple never offered a i9 chip in the 21.5” and the power supply and systems cooling won’t support it.
这个答案有帮助吗?
得分 1
3条评论:
If I were to use a chip with the same TDP as the original i7 it should work though right?
完成的
@kdn777 - The needed microcode would be the hang up as Apple never loaded the needed microcode in their firmware. Sorry 😞
完成的
Alright, thank you!
完成的
添加一条评论
添加你的答案
Kaden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 143
