Why can't my fingerprint sensor be used to unlock my phone?
After I serviced my cellphone screen, I found that my cellphone's fingerprint sensor could not be used to unlock my cellphone, but when used for other features such as opening applications, or approving other applications, I could use my cellphone's fingerprint sensor. Please help me...
Update (09/09/24)
I replaced my cellphone's LCD
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Hi, you might need to explain what servicing you actually did to your phone so that community can have enough information to help you to a resolution.
完成的
Did you try to reset fingerprint?
完成的
You may also check that fingerprint unlock is set to unlock phone. Go to settings and do search for fingerprint, then see what the options are set to for fingerprint.
完成的
I had fingerprint disabled message on iPhone after a screen replacement . Resetting fingerprint worked for me. If it doesn’t it probably points towards some internal damage.
完成的
添加一条评论
