跳转到主内容
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832 个问题 查看全部
Changing parts from one to another?
Hello, I wonder about the possibilities to use parts from iBook 12 inch LCD on the models G3 and G4. Parts as hard drive, battery, keyboard and well there must be more parts changeable? I'm thinking about buying used parts!
Thankful for answers.
Dick.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The LCD panel (But not the assembly) can be used in either computer, the batteries are also cross compatible, As is the hard drive, Keyboard, And charger. The logic boards, RAM, and Optical drives however, are not interchangeable.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
These parts can be swapped between the 12" iBook G3 and the G4
SCREEN ASSY:
- LCD panel
- front bezel (inscription wont match)
- hinges
- back cover (with Apple logo) color wont match
- inverter board
- display latch mechanism
NB: cables CAN'T be swapped (connectors wont match on logic board).
Other compatibles parts:
- keyboard (please read rj713 comment)
- battery (color wont match)
- AC adapter
- hard drive (IDE 2'5" HD)
- bottom case screws and rubber feet (color wont match)
All other parts are model specific and can't be swapped:
- ram
- optical drive
- top case
- airport card
- logic board
- heat sink
- internal metal frame
- DC in board
- HD & optical drive cables
- fan
- etc.
这个答案有帮助吗?
得分 4
3条评论:
IIRC some keyboards won't work on some upper cases of the same model because of a groove in the top case is required for a proper fit. Ralph
完成的
thanks rj713, I edited my answer.
完成的
Thank you. Nice to know.
Dick.
完成的
添加一条评论
添加你的答案
Dick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 951
