Only gets past apple screen when cold
Weird issue here. If it sits off and unplugged it'll get to the login screen before it freezes once or twice. Then just stays at apple logo. If I put it in the fridge and it gets really cold. It'll load up perfect and allow attempted logins then goes into a boot loop until the macbook gets hot. Then sticks at apple screen.. wtf? Gotta cool it down to try again.. I have never see this issue before..
What model MacBook is this exactly? It could possibly be a corrupted OS? Try SMC / PRAM resets to see if that helps 1st..... or a clean install.
由 livfe 完成的
It's a macbook pro with a 13" screen. Model A1708. I've done the resets. And doesn't help. Tried an internet recover too and it just freezes halfway once the computer gets warm.. if I could do that with keeping it in the freezer it may work. 🤣
由 Justin Lozar 完成的
@justinlozar It might help more to select the actual model from the list if you can MacBook Pro 13" Retina Display
由 livfe 完成的
@justinlozar - Let’s check the battery, install this gem of an App CoconutBattery post a snapshot of the Apps main window here so we can see it as well.
由 DanJ 完成的
Can't install any apps. Can't ever get past the login screen. It loads about halfway after entering password then loops back to the apple screen.
由 Justin Lozar 完成的
显示更多的10条评论
