跳转到主内容
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
20 个问题 查看全部
My screen is stuck at language setup screen.
Hi Team,
My Kindle was stuck all the time on home screen.
When I press power button it would popup option to restart, shutdown cancel however I was never able to select it.
Out of frustration I followed an article on Internet "Doing Factory reset using computer"
I created File without extension Do_Factory_Restore transferred to kindle performed factory reset.
Now my screen is stuck at language setup page.
  • I am unable to select get started 😑
  • I tried pressing hardreset for 40sec no joy.
  • I tried connecting kindle to computer it shows drive is not ready😓.
  • I have put my self in helpless situation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Is the touch screen working? It could be a screen issue.
完成的
Touch works on limited area rest feels like screen Is dead
完成的
It’s possible half the screen is dead , most probable in-fact as it’s a strange screen to be stuck on. Have you dropped it any marks or damage on or around the screen? I’m weirdly convinced my below answer will fix this.
If your not confident you could always take it to a repair shop for second opinion/ repair.
完成的
添加一条评论
2个答案
If you cannot do anything on the screen it is most likely a damaged digitiser. This can get damaged by a short fall or bump in the wrong place . Here’s a full guide and what to get.
Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
这个答案有帮助吗?
得分 0
添加一条评论
Try to turn off the screen using the power button and long-press it for a few seconds. If this doesn't work then try charging it for sometime. Restart your Kindle to resolve the frozen issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashley John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 39
