跳转到主内容
加入维修社区 - 创建账户
Power button Not work
I want to change my power button
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Okay
Here’s some info for other possibilities check first.
https://www.getdroidtips.com/guide-to-fi...
IfIXIT doesn’t seem to have a guide on this model currently . It’s a about a 6/10 difficulty I’d say. Easy if you take your time .
The switch Under the button is the likely issue. Not the button itself.
Here’s a replacement switch cheapest I could find. You can look it up on other sites. Just check it’s the same one.
https://www.aliexpress.com/item/10050038...
Here’s a guide play it slow a few times to get the idea. It’s pretty easy if you take your time.
https://youtu.be/diPz_m5H7lI?si=n_X5qUui...
这个答案有帮助吗?
得分 0
1条评论:
If you decide to do this why not replace battery at the same time? https://www.aliexpress.com/item/10050076...
完成的
添加一条评论
添加你的答案
Sanskar Upadhyay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 141
