跳转到主内容
加入维修社区 - 创建账户
Created in 2022 as an updated version of the prior model. It has a elegant look and a performance boost than the last years Tuf Dash F15.
My laptop's back cover pushes out a little on one corner while opening
The socket of the screw that holds one corner of my laptop's back cover is broken to bits, it pushes the back cover out a little on one corner while opening unless I hold it tight. Can i fix that socket by putting some plastic powder around the brass inserts and bonding it with Flex Kwik PVC adhesive??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I have this too. Did you manage to solve the problem?
完成的
添加一条评论
1个答案
No reason why not just don’t get any anywhere else!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melvin Francy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 143
