跳转到主内容
iPhone 13 mini 于 2021 年 9 月 24 日发布,它是 Apple iPhone 13 的缩小版,也是第二款的迷你 iPhone。 iPhone 13 mini 具有 5.4 英寸 OLED屏幕、A15 仿生处理器和后置双摄像头。
iPhone 13 mini to a iPhone 12 mini
Is it Possible to take everything from a Iphone 13 Mini and sett everything in it to a Iphone 12 mini. Becuse i have a 12 mini case thats like brand new. And my iphone 13 mini case is damaged. I mean they have exact hight and display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
CORRECTION: It maybe can. Though, that pictured case does not look like an iPhone 12 mini case, it looks more like an iPhone X-style case judging by the size of the camera module.
这个答案有帮助吗?
得分 0
3条评论:
I'm referring specifically to that black case pictured. As for the internals, I can't properly answer that as I haven't laid hands on any of the iPhone minis.
完成的
its just n iphone X on the picture. not iphone 13 mini i lay it there just becuse i didnt find any orther picture at the moment
完成的
Ah. Just for future reference, it helps to have an accurate picture with the device you're talking about rather than an unrelated device. Thanks for clearing that up though.
完成的
添加一条评论
Hi, I’ve wondered this in the past with different iPhones never tried it. Things to find out, are the screw holes and threads the same size and location , screen clips etc. I would look for back housing images for both phones is everything internally located exactly the same ? Compare repair guides maybe for screw sizes, locations. So my answer is I doubt it but maybe 🤷‍♂️
这个答案有帮助吗?
得分 0
3条评论:
I think there may have been some slight internal changes between the 12 and 13, more specifically relating to the screen and the stuff inside of the notch. it *could* fit but I really doubt it.
完成的
iphone 13 mini is Deeper and 63 millimiter thicker. so it isnt possible i find out now =D
完成的
That’s settled that one then . You should get your screen fixed though 😉
完成的
添加一条评论
添加你的答案
Markus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 27
总计 246
