跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
Yellowish Box on the Screen Display after Water Damage
Hi After a couple of months (since May 25th) of trying to repair my MacBook Pro 2018 15’inch due to water damage, a repair man was able to turn it on but it has this Yellow Box on the screen. Is it possible for the Water to have the screen having that Yellow Box on the screen? The water only had contact with the inside cause it enter only through the bottom panel vent hole of the MacBook. Now I have this Yellow stain on the screen.
Please is there anything that can be done or I hope would solve the Yellow box on the screen issue? Water never got to the screen how could it be and if it the water destroyed the board components working with the screen display can’t it be cleaned or something so it doesn’t affect the display.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m so sorry your displays data ribbon cables have been damaged. You’ll need to replace the display assembly following this guide 2018 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Big Sul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 80
