跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 个问题 查看全部
games crash and google tabs
My pc games were crashing a lot turns out it had a overheating problem so we took it to BestBuy to fix it they said i needed a new CPU fan because mine wasn't enough we got a new one on amazon it was fine for a day. Then randomly my games started crashing again so were my google tabs while watching Youtube.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @tun3,
What are the specifications of the PC i.e. make and model number of the motherboard, CPU, GPU, PSU, and how much ram is installed?
Has it worked OK playing the same games before?
Does the PC meet the minimum hardware system requirements of the games that crash?
完成的
添加一条评论
1个答案
Set manually or to default all the power s. for the CPU under the bios, try to get/buy a good cooler for anything 100w+TDP CPU (like amd ryzen or intel 3ghz stuff) , don't activate turbo in bios if you have issues under gaming, if it's AIO(water cooler, try checking the water lvl or pump funcitonality).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tun3 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 16
