跳转到主内容
加入维修社区 - 创建账户
苹果 14 Plus 采用 6.7 英寸 OLED(与 Pro Max 一样),和iPhone 14 一样,iPhone 14 plus 具有双摄像头和 5 核 GPU 的仿生 A15 芯片。
Cellular Issue - unable to access cellular data
Water damaged, dried out by opening the back and front keeping in rice for 12 hours. Phone came back on. Old screen no display so put a new screen and the replacement works. Two Problems Cellular Issue (no bars no net) and Phone keeps restarting.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
It looks like water has affected the motherboard. iPhone 14 has a dual motherboard; the top board is for UI, and the bottom is for communications (network/cellular). Water ingress can affect the connecting layer and cause corrosion between the pins. This could be the reason why the iPhone is restarting and does not have cellular (baseband)
This is going to be a chip-level repair, and only a trained professional can perform such complex repairs. The boards will have to be separated, serviced, corroded parts replaced, and the boards reballed and refixed.
BR
Francis
CelMetro
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arbin Shrestha 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 34
总计 287
