跳转到主内容
加入维修社区 - 创建账户
Repair information for LG dryers.
Timer won't shut dryer off
I have the same problem on an LG DLE4870W dryer. The On-Off button and the Pause-Start button seem to work normally, but the drum continues until I shut it off at the breaker.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi @duanedecker
Try running the diagnostic tests and check if any error codes are displayed when testing the various functions of the dryer.
这个答案有帮助吗?
得分 0
添加一条评论
Define what you mean by "normally". If the drum doesn't stop, how is that normal?
The drum control is separate from the heat control. If the drum doesn't stop, the part that runs it, probably a relay, is sticking.
That could be because the signal to the relay is malfunctioning or the relay itself is bad.
If turning on the breaker again does not restart the drum, then it is more likely the relay control is malfunctioning.
Power is removed from the relay by the control or the breaker. So, if it restarts after turning off/on the breaker, the relay is stuck.
If not, it is the control.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Duane Decker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 197
