跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
My phone wont charge unless switched off.
Hi,
I have an Iphone 4, jail-broken running IOS 5.0.1.
It has been working (jailbroken) for some time without issue. While it is jail broken, I don't have anything installed outside of default stuff that RedSn0w puts on.
Suddenly, it refused to charge or connect to itunes. I have tried wall chargers, computer charger and multiple cables. All of these fail.
I have tried hard resets. I have tried putting it into DFU mode and connecting. This fails (so probably not software?). I have tried a IOS software update via wireless, which fails.
I can only charge my phone by connecting it to a charger and then switching the phone off. If I switch off then connect to a charger, the phone switches on and wont charge.
It is out of warranty (and jail broken) so taking to a apple store is not an option.
Has anybody got any ideas? if it is hardware, what are the likely culprits?
Regards
Mark
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Thanks pcmaclinux
完成的
添加一条评论
4个答案
已选择的解决方案
Probably the dock connector is the fault. Replacing it is not easy.
I would still recommend to take it to apple and pay a huge sum of money or just buy a new iphone.
If you want to try to replace it, here's a link to a replacement dock connector for GSM models:
[关联产品丢失或禁用: IF182-009]
On that page there is also an install guide.
这个答案有帮助吗?
得分 0
添加一条评论
Hi there It too easy to change.I got same problem for my i phone I bought part from online store and replaced by myself .Its work proerly again i phone 4 Dock connector under $20-$30 you can do your self . www.mobilepro.com.au
这个答案有帮助吗?
得分 0
添加一条评论
that was the problem ...70$ at a kiosk in the mall
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I had the same problem and tried many things but just fixed it so want to share it here for other people's benefit.
My problem: my iphone 5 won't charge or connect to itunes. The cable and connector is fine because it only charges when the phone is off. So it goes into a loop where it charges till 2% then the phone turns on automatically and then stops charging.
It does not respond when I plug it into my laptop for itunes.
I've tried the hard reset (holding home button and power button), but it doesn't reset the phone. The phone just turn off.
This problem persisted for a few days. I was able to recharge the phone by running it till the battery is empty and then plugging it in and leaving it overnight.
What worked:
Finally, I tried switching off the phone and plugging it to my laptop. itunes finally detected it and said it has a problem, recommending a software upgrade and restoring if the upgrade doesnt fix the problem.
But halfway through the process, the message said software upgrade failed but my iphone is able to charge and connect again.
So that's how it got fixed.
So try it if you have the same issue.
这个答案有帮助吗?
得分 0
3条评论:
i have same problem :X leptop did,t detecting :X
完成的
me too. My iphone 4s doesnt connect to the laptap.
完成的
Clean charger port first. If that fails replace dock connector.
完成的
添加一条评论
添加你的答案
mhnathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 21,892
