跳转到主内容
The Dell Latitude 5480 launched on January 26, 2017. It is part of the Dell Latitude 5000 series.
6 个问题 查看全部
My Windows 11 wont Hibernate at all.
Hi I need help
My laptop won't hibernate as soon as I click hibernate screen goes black and then goes to the login screen. However, it can go to sleep though.
Dell Latitiude 5480
Edition: Windows 11 Pro
Version: 21H2
Installed on: ‎30/‎1/‎2023
OS build: 22000.2538
Experience Windows Feature Experience Pack 1000.22001.1000.0
Kind regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @dumisaningwenya
Try the following, one at a time and check if any resolve the problem:
a). Reset Hibernation -
Type cmd in the search box on the Taskbar and select Command Prompt > Run as Administrator
Accept any UAC prompts to open the Command window.
Type the following commands one at a time and hit Enter after each command
powercfg –h off
powercfg –h on
Note: Yes there is a space between some of the characters as shown
Exit the Command window and restart the laptop and check if Hibernation now works OK.
b). Check that all the system files are OK.
In a Command window as above type sfc /scannow and hit Enter and then after the checks have finished restart the laptop in the normal manner and check.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dumisani Ngwenya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 22
