跳转到主内容
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
How repairable is the hardware microphone mute button?
The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece. I'd rather avoid replacing the whole headset due to the price.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Somone said they used wd-40 contact electric spray on it and that solved it, others say you keep pressing and unpressimg the mute button, if you still have warranty contact manufacturer.
If you're a tinkerer you can disassemble the headset and clean the mute button from the inside, if that doesn't solve it then I would put a small solder point on its tip from the inside and keep it unmuted all the time and not play with it, maybe use software matting instead after.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Corey Sutlief 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 64
过去 30 天: 322
总计 1,479
