跳转到主内容
惠普台式机维修指南。
HP EliteDesk 800 G2-Tower failed memory initialization
I got this old HP EliteDesk 800 G2-Tower PC from the scrapyard and I don't know if it worked before, but I assume it did. There was no CPU and no RAM in it when I found it but I also have multiple i5 6500 and 2x8 GB RAM. I tried every CMOS/BIOS reset option and also different CPU/RAM combinations. I always get 3 red und 2 white led blinks which according to this means "The embedded controller has timed out waiting for BIOS to return from memory initialization" and I don't really know what to make from that. The motherboard has a green led that lights up and the CPU also spins up when I connect the PSU.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
When I used my pc 20 minute my PC is shutdown automatically
完成的
What do you mean? Do you also get three red and two white blinks?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @leo9444
Just verifying that by "...every CMOS/BIOS reset option..." you also tried resetting the BIOS by disconnecting the power to the PSU, removing the coin cell battery from the motherboard and then pressing and holding the Power On button for 20 seconds, then reinserting the battery, reconnecting power to the PSU and turning the PC on to check if this resolved the problem?
If it did, if the coin cell battery voltage is <2.5V DC or the battery is >4-5 years old, replace it.
If you did and it still didn't work here's the schematic if you're interested.
这个答案有帮助吗?
得分 1
1条评论:
Yes, I tried exactly that and also replaced the CMOS battery. Thank you for the schematic, maybe I'll take a look and do a few measurements..
完成的
添加一条评论
Hi,
You might consider downloading a BIOS update for it to see if flashing the BIOS will resolve the hang.
Download BIOS and create a USB boot disk to run the BIOS Update.
Hope this helps
这个答案有帮助吗?
得分 0
1条评论:
I created a drive with "HPBIOSUPDREC64". Unfortunately, the PC doesn't "react" to a USB drive with the BIOS update on it, and it still blinks immediately after turning it on.
完成的
添加一条评论
添加你的答案
Leo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 409
