跳转到主内容
First generation, based on the Ford C1 global platform.
How to change Gasket seal
2004 mazda axela. Engine leaking I have seal but not sure how to replace
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi robyn,
Can you be a little more specific? Exactly which seal did you buy? There are several on any given engine, so it's important to know which one you're trying to change.
完成的
添加一条评论
1个答案
  • Prepare the Vehicle: Park on a level surface, disconnect the battery, and ensure the engine is cool.
  • Locate and Access the Gasket: Identify the leaking gasket, and remove any parts obstructing access.
  • Clean the Surface: Remove old gasket material and clean the area around the gasket.
  • Install the New Gasket: Place the new gasket in position. Apply sealant if required.
  • Reassemble and Check: Reinstall removed components, tighten bolts to specifications, and check for leaks after starting the engine.
这个答案有帮助吗?
得分 0
2条评论:
This looks like a typical AI generated answer to me; reasonably accurate yet at the same time pretty much totally useless.
完成的
ok cool thanks
完成的
添加一条评论
添加你的答案
robyn alker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 130
