跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
My 3ds won't charge but will turn on
the 3ds turns on, the orange charge light doesn't turn on when plugged in.
before it stopped i had to hold the charger at a wonky angle for it to charge at all.
when it could charge only a specific ac adapter worked. (which can charge my dsi, therefore the charger still works)
im not sure if it's the charging port or the battery (or something else).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
You could try cleaning out the charge port to see if that helps.
There are lots of YouTube videos available to guide you through the problem.
I would start with a search for Nintendo DS3 won’t charge.
Hope this helps
这个答案有帮助吗?
得分 1
2条评论:
yep, fixed it.
the yt vid I used: https://www.youtube.com/watch?v=oZrprlK7...
完成的
Good stuff 👍
完成的
添加一条评论
添加你的答案
Reign 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 64
总计 828
