跳转到主内容
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
iPad 3rd Gen Digitizer the same as 2nd Gen?
Can I install a 2nd Gen iPad Digitizer into a the new 3rd Gen iPad?
If so, is it an identical match?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Was wondering the same thing. I want to get a color conversion for mine but all of the ones I've found have been iPad 2's...
完成的
I checked my ipad imei and said it was an ipad 3G. My touch screen was cracked so i need to replace it. The question i have no see ipad 3G it always ipad 3 in selling touch screen. Can i buy ipad 3 touch screen to my ipad 3G it will work? Please help me.
完成的
no they are different
完成的
添加一条评论
10个答案
已选择的解决方案
They appear to be different parts (iPad 2 digitizer, iPad 3 digitizer).
That said, I've scrutinized the photos from the iFixit teardowns of both the iPad 2 and iPad 3, and darned if I can see any significant differences. The metal shield around the camera appears to have grown a spring-contact on the iPad 3 to improve contact with whatever it touches, but that looks like it. And it would be very in keeping for Apple to use the same part for both iPad 2 and 3 if they function the same way. The logic boards of each of the two even have their various connectors to the screen and speaker arrays in the same spot.
So: inconclusive. Maybe we'll luck out and an iFixit staffer will compare and contrast the parts for us.
Replace a scratched or cracked front glass digitizer screen. This part is compatible with an iPad 2. This part does not include the home button assembly.图片
产品
iPad 2 Screen Digitizer
$24.99
Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad.图片
产品
iPad 3/4 Screen Digitizer
$24.99
这个答案有帮助吗?
得分 4
1条评论:
Thank you. It would be nice of iFixit to that ;)
完成的
添加一条评论
最有帮助的答案
The board sockets (connectors) are the same. The iPad 3 digitizer cable is longer though. So, as stated above, you can use the iPad 3 diggie on an iPad 2 with a couple of folds on the longer cable. However, you wouldn't be able to use an iPad 2 diggie on an iPad 3. The cable just isn't long enough.
IndyElectronix
这个答案有帮助吗?
得分 6
添加一条评论
I just replaced an iPad 2 digitizer with an iPad 3 digitizer. Although the flex cable is different in length, it still fits the mainboard connector and has a couple of extra folds that got tucked under the screen, as far as I can tell, it works.
这个答案有帮助吗?
得分 5
1条评论:
Mark Richard,
Please let me know, after you replaced it and completed every thing, did the digitizer looked fit on the ipad?? or there was some kind of problems??
完成的
添加一条评论
iPad 2 digitizer does not fit iPad 3 the flex cable is totally different.
这个答案有帮助吗?
得分 2
1条评论:
see above you just repeated what he said lol
完成的
添加一条评论
I believe the connector is in a different location. I'll be doing one in about 2 weeks and can update as I have the iPad 2 in stock.
这个答案有帮助吗?
得分 1
添加一条评论
I would not do it. The ribbon cable is longer and is at a different angle. See photo...
This can result in a problem sealing the screen...
这个答案有帮助吗?
得分 1
添加一条评论
Will a ipad 2 digitizer fit a ipad 1?
这个答案有帮助吗?
得分 0
3条评论:
Not a chance. Different size and design.
完成的
I want the other way around. I have an IPad1 in pristine condition and my daughter IPad2 glass screen has a big crack. Can I swapped it out from Ipad1 to Ipad2 since my Ipad 1 is just a glorified wall clock?
完成的
iPad 1 and 2 are too different. Better buy a new third part digitizer for the iPad 2.
完成的
添加一条评论
What about the lcd would a 3 fit a 2 and other way around?
这个答案有帮助吗?
得分 0
1条评论:
An iPad 3 LCD will not fit an iPad 2 at all the connector is different: 3 has a ZIF socket and 2 has a metal connector with a metal clip and 3 is a retina display these are incompatible.
完成的
添加一条评论
I just replaced a white iPad 2 screen with a black screen replacement and there seems to be a noticeable difference in the screen size. It doesn't quite fill the frame. Did I get the wrong screen ?
这个答案有帮助吗?
得分 0
添加一条评论
Use the iPad 3/4 touchscreen, just fold the flex cable and tuck it under the LCD, make sure you don't tear it or rip it. it will work. I been doing this for years. The camera bracket is different, just swap it for the broken one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MacBroke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 60
总计 27,545
